Connecting desktop PC to LG Tv
Discussion in 'LG TVs Forum' started by Ter809, Mar 5, 2013.
  1. Ter809
    Ter809
    Feb 22, 2013
    11
    Hi all,
    I'm trying to connect my desktop pc (not a laptop) to my LG led tv (42LM649S) to use it as a monitor through a 15-pin male vga-vga cable (and no pins are missing). I think I'v gone through all possible solutions to try to make it work, but all I ever got was 'Input Blocked' from my tv. My pc does not have an HDMI out so I can only connect the two via the vga cable. I connected the vga from the pc to tv, and a dvi cable from the pc to my original monitor, so as to set the display from the control panel. I have adjusted the resolution according to that of the tv's. The thing is that the pc detects the tv because as soon as I connect the vga, LG TV appears in the display list. However, no display appears on the Tv.
    Can anyone help me on this please?
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread moved
    Curly
