Christoc
I bought a 'DVD Recorder + VCR' model: Daewoo DF-4700P many months ago to record some special memories off VCRs and 8MM tapes.
Now i have time to start looking into getting it working ive found i dont actually know what im doing!
I thought it would be easy, but im facing challenges as it doesnt look like my TV is compatible ( 'Samsung UE43NU7020' ).
It came with:
- SCART cable
- 2 Coaxial Cables and
- a small unit that has a male and female SCART port and a Red, White, Yellow input, (The wording saying "TO AV SOURCE" below the Male SCART, "TO TRANSMITTER" above the R,W,Y input and "TO TV" above the female SCART. See attached pic.
Maybe do i just need to buy an RCA Audio cable to go fro the device to the TV? and then plug the device into the Daewoo box?!
All advice really appreciated!
Thank you very much!
It came with:
- SCART cable
