connecting creative zen touch to a blaupunkt head unit
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by adder1234, May 20, 2005.
  1. adder1234
    adder1234
    I have just bought a new car (holden (or vauxhall depending where you are) astra) that is factory fitted with a blaupunkt 520 (this is what is on the face, i don't have the cars books yet to verify the exact model no.) headunit which is 99% sure would have the ability to connect a stacker to it.
    I have a creative zen touch i would like to connect to it via a stereo audio jack, is this at all possible? Also i would like to know of a good amplifier unit to connect to this stereo.
    Much appreciated, Adder (AUS)
  2. deltatech
    deltatech
    This procedure may not be exact but it's close:
    Turn radio ON
    - CODE - appears
    Press AS button for 5 second (maybe longer)
    "10 _ _ _ _" appears in the display
    Repetedly press Preset button 1 until the 1st digit (W_ _ _ where W is the 1st digit)
    is the correct value of the code for that digit
    Repeat with preset 2 (WX_ _ ) - 2nd digit
    Repeat with preset 3 (WXY _ ) - 3rd digit
    Repeat with preset 3 (WXYZ ) - 4th digit
    Hold AS button for about 5 - 6 seconds approximately
    Of course it may be possible that the Z (least significant digit can be entered 1st - don't know & don't care - I have wasted enough bloody time on this!)
    :thumbsup:
