connecting computer to sky+ box???
Discussion in 'Sky Digital TV Forum' started by astep70uk, Apr 9, 2005.
  1. astep70uk
    astep70uk
    Hi, this is my first post here, so please forgive my ignorance.
    I am thinking of getting sky+ installed, but I want to be able to archive off cartoons to DVD for my son to watch. I was thinking of buying a dvd recorder to connect to the box, but i wondered if it would be possible to connect my Formac TV digitizer box, and my laptop, which has a DVD recorder. Any ideas as to what connections are in the back of the box etc, and if this is a viable idea??? Thanks
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    SKY+ has a couple of scarts (one RGB), an s-video output (which is probably the best option) and two RF outputs.
    There are the normal twin RCA phonos for audio as well as an optical output.
    A combination of the s-video and phonos should provide reasonable quality and ease of setup and DVD authoring software can do wonders for homemade discs:)
