connecting coax outside
Discussion in 'Cables & Switches' started by rhoamish, Jun 20, 2003.
  1. rhoamish
    rhoamish
    Does anyone know if there's a natty device for making a connection in Coax, on an outisde wall?
    For slightly confusing reasons I had to cut through the cable between the satellite dish and sky box, and now I need to join them together again...
  2. Kearney
    Kearney
    Nov 4, 2002
    85
    11
    Wiltshire
    +4
    Bad luck you had to cut the cable, as it is best to have an unjoined length from the LNB to digibox. However you could use 2 'F' connectors and a 'F' connector joining barrel to join the 2 pieces of coax, then use a piece of heatshrink sleeving or insulation tape wrapped around to keep it dry.
    You can get satellite 'F' connectors from good hardware stores on online from Maplin or CPC.
  3. Arthur Dent
    Arthur Dent
    To keep it weatherproof, use "self amalgamating" tape instead of ordinary insulation tape, that's what satellite installers use to keep connections to LNB dry. That also is available from Maplins.
  4. Fernsehman
    Fernsehman
    The information on this page might help.
  5. rhoamish
    rhoamish
    Thanks for all the help! I was nervous about cutting the cable, but I'd already done it once to fit a proper socket on the wall, rather than having the cable just bunged through the wall.
    I made the outside connection using an indoor 'clamp' type connector, then covered it in silicone sealant, then wrapped it in duck tape. As you can imagine, it looks beautiful.
    However, there's no drop in picture quality! It looks no different to before.
    Has anyone else found this?
  6. Fernsehman
    Fernsehman
    Generally, a digital picture is not going to suffer from any loss in "quality" because of bad connection to the LNB. However, if the connection really is badly made, it can affect certain spot frequencies and you could end up with some channels missing or suffering "picture freeze".
    If you experience that, now or in the future, you'll know why!
    Fman
