Connecting ceiling speakers to Amp and TV
jimbobme
Hi all, new here.
I have been given a Sony Amplifier by my brother (STR-DB790) as he no longer uses it. It is quite an old AMP (no HDMI for example) but I want to use it to play TV sound through my ceiling speakers. I had them installed (but never connected to anything) when I had some refurbishment work done so all wires could be concealed.
I have a smart TV and a sky Q box. Right now I have HDMi from Sky Q to Tv and sound from TV. My speakers have standard speaker wires unterminated near my TV.
can anyone help me understand how I connect the amp, TV and Sky Q together so that when I connect the speakers to the AMP the sound comes from the speakers?
The only common connection I see on all three is optical audio.
Joe Fernand
AVForums Sponsor
SKY Q
HDMI Out > TV HDMI In
Optical Out > AVR Optical In
TV
AVR
Loudspeaker Front LR Out > LR Ceiling Speakers
Ensure you configure the Sources devices and AVR for Stereo Out - you will also want to consider adding a Sub to the system as ceiling speakers on their own can sound pretty bright.
Joe
jimbobme
thanks Joe. One question - I note you have both Sky Q and TV -> AVR Optical In. there is only one Optical In on the AVR; do i just need to get a two way splitter for the AVR ? Thanks
Joe Fernand
AVForums Sponsor
Either a 2x1 Optical Switch or if you are sticking with the Stereo setup you can connect SKY Q via HDMI to the TV and route the SKY Q audio via the TV Optical Out - I’d start with that if you only have a single optional Input on the AVR.
Joe
