Connecting CD player
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Vodder, Sep 30, 2004.
  1. Vodder
    Vodder
    Jan 11, 2004
    449
    London, UK
    +8
    Random thought...
    Could you connect a CD player via the left/right phono out connections to the left/right phono in connections on a TV and use the speakers on the TV to listen to CDs?
    I'm sure this tehory works because I use a similar setup to connect sound from my PC. I just want to double check it...
  2. Ovation
    Ovation
    It should work. It won't harm either the player or the TV to try.
  3. Vodder
    Vodder
    Jan 11, 2004
    449
    London, UK
    +8
    I thought it would, just not sure what the volume levels will be like.
    I know when I connect the PC to the TV, you have to turn the volume up quite a way.
  4. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    Vodder I may be appear dense here but :
    But are you sure these TV anlg L/R jacks are actually inputs ? serious question. Or is it some fancy surround TV with sat speakers and an onboard amp ?
    Anyway on a related note if you need to hear CDs via a TVs speakers, simply hook up a DVD-V player via a 21 pin RGB Scart, when playing a CD the sound goes via the L-R audio pins. OK not high fidelity as per a hifi setup but perfectly acceptable boom-box wise, remember no matter which way you connect the sever limiting factor here is your TVs speakers.
    HTHs
  5. Vodder
    Vodder
    Jan 11, 2004
    449
    London, UK
    +8
    I presume it has some sort of onboard amplifier, it has 3 speakers you attach for Nicam and 4 scarts.
    I was going to use the L and R from one of the scart sockets to connect. I think this will work bcuase the sound from the PC is connected in the same way. I was more concerned about damagin either or. I can't use a DVD player to listen to Cds as the DVD player I have is downstairs and I have a dedicated CD player upstairs and want to utilise that.
  6. Vodder
    Vodder
    Jan 11, 2004
    449
    London, UK
    +8
    Well cor blimey - I expected it to work, but not that good!!! :eek:
    Got a very mint condition Arcam CD73T at a very nice price (will wait for the DAC route, just non about in my price bracket) and CDs sing!!!! Even connected through the TV!!! Can't wait till I got a small integrated amp for the bedroom and then I can rig up my spare 601s!!!! :D
