Connecting CD player and Onkyo 876 please help!
Discussion in 'AV Receivers & Amplifiers' started by Bencar34, Feb 13, 2009.
Tags:
  1. Bencar34
    Bencar34
    Feb 10, 2009
    Hello, thanks in advance to anyone who answers or suggests ideas to me!
    Here is my question (problem). I have decided after long consultation with my personal bank manager (wife) to purchase the Onkyo 876 and integrating it with my hifi.
    (Linn Classik K running Linn Ninkas)
    So upon reading the instruction manual for the onkyo (some men do read these!) I have decided to use the Bi - amp (not bi-wire) function of the onkyo to run the speakers.
    Now I assumed that I was to run interconnects from the CD pre amp out into the CD in on the onkyo.
    I thought that as it was coming from the CD's pre amp out that the CD player would have no volume changing capabilities at all (i.e. it was just providing a signal) but this is not the case both CD and amp are able to control the volume!
    I am assuming this is not good!
    So here is my question
    Should I set the onkyos volume and change the volume on the CD player (if so what do I set the onkyo to?)
    Or should I set the CD at a designated volume (say about half of max i.e. 50 on a scale on 1 - 100) and control the volume with the onkyo?
    Please help
    Thanks Ben
  2. dwhite
    dwhite
    Dec 13, 2001
    7,414
    Whitehaven
    +1,805
    Do you need to run the cd thru the the onkyo? The Linn Klassik is already a combined amp and cd player, which I suspect is probably a better unit for stereo amplification than the 876.
    If you want to incorparate your Ninkas into your 876 setup, I would suggest using the pre outs of the 876 to the classik. That way you are using the superior amps in the classik for stereo reproduction.
    Either way I would set the volume to 50% on the classik and use the 876 to control the volume.
  3. Bencar34
    Bencar34
    Feb 10, 2009
    Thanks for that. Another question then if I may?
    I originally wanted to use the onkyo to bi-amp the speakers, when previously I had them running in a bi-wired configuration from the Classik is this the same?
    Cheers you advice and help is much appreciated (Ps I didn't really notice any difference between the bi-amp config with the onkyo and the bi-wired from the Linn should I?)
    Ben
