Connecting both FM and DAB Aerials
Discussion in 'Music Streamers' started by Nigel12, Jan 17, 2008.
  1. Nigel12
    Nigel12
    I'm new to DAB, so looking for some help. I've search the forums and can't find the exact answer I'm looking for, but I now understand a lot more.
    I have just got a new DAB tuner for my HI-Fi. A Denon TU-1800DAB. It has connections for both DAB and FM aerials. so I assume that I need both conected for a good signal when I swop between the two
    I had therefore assumed that I would be able to find a wall plate with two connections, one for FM and one for DAB, but all the twin wall plates I can find seem to be TV and FM/DAB, which only gives me one aerial point for the tuner.
    Does anyone know where I can get one, or am I looking for the wrong thing? Or one I fitted a DAB aerial to my system, can I just run both the FM and DAB aerial from a single point.
    Some background info:
    My old Tuner was plugged into a FM wall socket. The cable to that wall socket runs up into the loft into some sort of "multiplex unit" (don't know exactly what make) into which is currently plugged
    A loft mounted FM aerial
    A loft mounted TV (UHF) aerial
    A feed from the my Sky+ HD box
    There are then single distribution leads to most rooms in the house, which carry a combined signal.
    There is a input for a DAB aerial into this unit, so I was planning on mounting a DAB aerial, plugging it in and then I would get DAB added to the combined signal.
    My understanding is that its the filter in the wall plate which then takes the signal I need in that room. So currently, my main HI-FI (where the new turner is replacing an old FM only one) I have a single FM wall plate. In the main bedroom I have a wall plate that splits to TV and FM from the single cable and I run both a TV and a small Hi-Fi from that. While in the kitchen I just have a TV.
    Thats why I assumed I could get a wall plate which was FM one side, DAB the other.
  2. JimNoble
    JimNoble
    Aug 2, 2002
    63
    Hemel Hempstead
    +7
    I'm sure I've seen one that was TV/DAB + FM. I'll see if I can find a link...
    Jim
