Connecting AVR300 to a CRT TV via RGB
TimHiFi
I read my Arcam Manual, and I am convinced that I can connect the AVR300 high quality video output to my Sony 100Hz CRT TV.
However, the man in Sevenoaks in Reading say that I am mistaken ?
OK, the manual says I can't take RGB from the amp and send it into a TV that has RGB Sync on Green.
But most CRTs also have composite going in on the SCART too, so I can connect from the amp to the TV with RGB and composite (to provide the sync).
Does anyone know if I am correct in my assumptions, or is the man in Sevenoaks correct.
The SCART to 4 phono cable (RGB + Sync) from QED is about £70 ! so I'd like to know if its possible before buying one.
If not, then I guess I'll continue to bypass the video section of the amp, as I'm doing now. However it would be nice to see the TV screen menus other than through the grotty composite connection I have now ?
I assume Sony TVs will accept RGB + Sync on composite will they ?
Tim
A
Andy_61
I too have wondered about this possibility - Sevenoaks Sheffield seemed to think it was do-able, provided one had the scart to 4phono cable.
Can anyone suggest a reason for it NOT working?
Regards,
ANDY
TimHiFi
Basically the question I/we are asking is whether most modern TVs are
a) RGB Sync on green i.e 3 phonos to SCART
or
b) RGB Sync on Composite i.e 4 phonos to SCART
I think its a, or b ... its just an expensive cable to buy only to find it won't work :0(
The Arcam seems to be pretty unique in this RGB output to a standard CRT using 'component' RGB
Perhaps our resident Arcam Engineer might pick up,on this post ?
R
Robin Francis
Option B. This is how I have it connected to my Philips TV. I think that this is also the standard for SCART.
/Robin
TimHiFi
Thanks Robin
Seeing as you have it working ... it must be true.
Might give it a go.
Are you using the QED cable or another one ?
R
Robin Francis
I built my own cable using Supra AV 6.4 cable, Supra RCA-3 and Supra SCART connectors. Fantastic result! Most TVs aslo require that the SCART input is triggered to use RGB. The RGB-trigger output on the AVR250/300 is used for this. If this is not used the TV only uses the composite signal. This was the case with my Philips TV.
/Robin
A
Andy_61
Thanks, Robin.
Not being the most competent of people with a soldering iron, I think I'll just approach those nice QED people :thumbsup:
R
Robin Francis
Remember the RGB trigger. The QED SQUART AV19 and AV29 does not have it. Maybe they have a custom cable ?
/Robin
Lefreck
Hi Robin,
As you are using the RGB-output from the AVR300, have you tried if interlaced YUV signals are "transcoded" to RGB?
R
Robin Francis
The AVR250/300 does not convert YUV to RGB or vice versa.
Similar threads
Podcast: LG SN7CY Soundbar Review, Hisense 55U7Q, LG Nano90, Best of the Month, B+W Sigourney Weaver
