Connecting AV amp to Projector
Discussion in 'Cables & Switches' started by BigTone, Feb 17, 2003.
  1. BigTone
    BigTone
    Feb 11, 2003
    2,623
    +1,255
    Ok,
    Now I'm gettign all excited, looks like a projector is going to be coming sooner rather than later :)
    A quick question about connection. My AV amp is the Denon 10SE, and my DVD is using the component inputs (Y, Cb and Cr), my Sony PS using S-Video input, Sky using S-video input. Initially I was palnning to use the S-video output to connect to my projector, but I'm thinking that this is not the best option. However, if I use component out, will I get a signal from the S-video inputs? or will I have to run both? Or should I run direct from DVD to projector and miss the amp out?
    Obviously my better half doesn't want more cables running the length of the room, and I do believe that I told her just one cable would be required (and of course the cables for the rear and side speakers :-!) I can run the cables inside the coving.......
    (JFI the room is 16 foot long and 12 foot wide, solid concrete floor, joists running width ways, floor above is not boards and recently carpeted)
    Tone
    PS my partner has now realised that the DVD player she bought as an xmas present has turned out to be the most expensive even :)
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Why not get an rgb-component convertor for sky and a component lead for the PS.
  3. BigTone
    BigTone
    Feb 11, 2003
    2,623
    +1,255
    There is only 2 comp. inputs on the amp.
    How does RGB component work for sky?
    Tone
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,378
    Somewhere in South Yorkshire
    +5,764
    I think the easiest/simplest/msst direct option is:
    Component direct from DVD to PJ
    SVideo from all sources into amp and then SVideo from amp to PJ.
