Connecting Arcam to my Denon !!Help!!
Discussion in 'Cables & Switches' started by CrispyXUK, Nov 13, 2003.
Tags:
  1. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,737
    71
    Land of the Living, Essex
    +35
    Hi all,
    Just got my Alpha 9 from Stevemdavis (Very Good Seller BTW) and I have no manual I was just wondering were the pre-outs from my Denon connect to it, is it "Processor In" or "Tape 2/Processor" im not sure which one to use and which buttons to press to enable the processor mode.
    Thanks for reading guys
  2. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,737
    71
    +35
    Anyone? someone must have an alpha 9?
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,183
    2
    +3,641
    I had a 7R (which was a hell of a lot simpler) and used to connect my DSPE800 into the tape ins but would in this instance try yhe dedicated "processor in" (presumably fitted with the AV50 in mind) which would keep the tape loop free.
    Ed
  4. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,737
    71
    +35
    There is a processor engage button on the front, but there is also an A/V processor -> normal switch on the back too, i'm confused
  5. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    Connect it to the tape 2/processor in. Set the switch at the back to processor. When using the denon select the processor switch on the front, when using sources connected to the arcam switch off the processor switch on the front. If it's working correctly then with processor switch "on", the arcam's volume knob should make no difference; when processor is "off" volume will again work with the arcam's sources.
