Connecting anynet + tv and blu ray problem
Looney14
hi all
I have sky and virgin pluGged into hdmi 1 and 3 ports on my Samsung tv
Hdmi port 2 has always had the Samsung blu Ray
For 3 years no issue I could hear sky and virgin out my blu Ray speakers - just had to put on mode d.in - default one when you turn it on
Hdmi ports within the blue ray self rarely used for Apple TV and android box
Anyway I could control the volume turn both devices off with tv remote
Sadly the hdmi cable connecting the two broke so I replaced but
Now they act totally SEPERATE and its so annoying
I have turned on and off both devices from power source and plug tried to re connect
But whenever I click tools / anynet + (hdmi cec) / device list / refresh
It finds "player" but if I try connect
It says connecting to anytime+ device then
ANYTIME+ DEVICE IS NOT CONNECT PLEASE TRY CONNECTION AND TRY AGAIN
WHAT CAN possibly TRY NEXT?
Anytime + hdmi - cec is turned on blu Ray
Picture audio is fine from blue ray
I turned it off for 10 mins from main
I even reset the blu Ray pin 0000
Could it be the new cable I bought? Maybe it's not 1.4 and 1.3 I think that's a condition - how can I check what mine is??? It's thick gold hdmi must be good!!!
Although it does pick it up....(says player in the list of devices)
What more can I do?!?
Gavtech
Administrator
Try a replacement cable - Any will do - Cheap is fine.
Looney14
I swapped the one that came with my sky dish for my gold plated blu Ray replacement
Synced up straight away :)
Must not have arc enabled 1.4 I'm guessing thanks!
