Connecting analogue feed to digital TV?
Deisel Weisel
My father just purchased this Panasonic TV. Up until now I’ve used an old analogue satalite box to receive EuroSport for free. Can I plug this into the new TV, either direct or with some sort of additional d/a convertor?
Chris Muriel
Yes. If you click on the "specifications" tab on the linked page that you posted you will see a "21 pin" socket mentioned.
That's a SCART socket - so connect your old analogue box to it via a SCART to SCART cable.
Deisel Weisel
Thanks Chris, I'll hook it up, see what happens. I was checking that TV’s spec list, and it appears to come with both digital and analogue tuners, so I guessed there had to be an A>D convertor in there somewhere.
JayCee
The Digital/Analogue tuners have no bearing on your ability to connect/view your satellite box.
It simply plugs into the scart socket as Chris mentions.
Deisel Weisel
I though the presence of an analogue tuner, would indicate an analogue to digital convertor onboard the TV, to enable an analogue picture on screen? Much like my analogue satellite feed would require the same? That’s what I was figuring was the potential problem in getting my sat box working with this TV, not so much the connection, but an onboard A/D convertor. No?
JayCee
No, in your case the signal from your satellite box is already in an analogue format and is connected to an analogue input scart socket on the Tv so there is no conversion needed.
