Connecting an xbox to vga monitor
Discussion in 'Cables & Switches' started by packmanuk, Jun 12, 2004.
  1. packmanuk
    packmanuk
    Jun 11, 2004
    1,032
    38
    +6
    I've got a TFT monitor I want to use to play my xbox games. My xbox is chipped and set to ntsc and most of my games are from the USA. I would like to use the highest resolutions possible to play my games. I need some advice on how to connect the 2 together so I can receive the best image quality. I have the following equipment at the moment but this can be exchanged if better is available -
    Progresive component vga box - link below
    http://www.consoleplus.co.uk/product_info.php?products_id=624
    xbox component video cable
    Is this all I need or am I missing something because at the moment I get no picture using the above equipment on my tft monitor.
