connecting an infocus 4805 to a laptop?
Discussion in 'Projectors, Screens & Video Processors' started by ENG, Jan 20, 2005.
  1. ENG
    ENG
    Hi hope you guys can help, I am borrowing an infocus 4805 projector tomorrow night to do a powerpoint presentation, I know nothing about projectors and need to know what cables I need to connect this up to my laptop. thanks
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    The 4805 comes with a PC cable but it's M1 to DVI/USB which is fine if you have DVI out on the PC
    You will need a M1 to VGA cable with a laptop with a 15pin HDD VGA socket.
    The M1 connector is like a wider version of a DVI connector, the extra pins being for the USB connector on the other end of the cable.
    Jeff :rtfm:
  3. ENG
    ENG
    Still a bit confused I have a new dell lap top and these are the ports I have
    2-USB 2.0 (Universal Serial Bus) compliant 4-pin connectors
    TV-Out (S-Video-Out): 7-pin mini-DIN connector
    IEEE 1394 (Firewire): 4-pin serial connector
    Fast IR (Infrared): sensor compatible with IrDA Standard 1.1 (Fast IR) and IrDA Standard 1.0 (Slow IR)
    Parallel port: 25-hole connector
    Serial : 9-pin connector
    Video: 15-pin monitor connector
    Do I still need this M1 to VGA cable? If so where can i get one quickly any links? Pc world?
    thanks
  4. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    You will to still need a M1 to VGA cable to use with your laptop.
    Do a google search for: M1 to VGA cable
    Jeff :rtfm:
  5. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,684
    Woking
    +230
    Actually the 4805 does not come with a M1 to DVI, it comes with a M1 to VGA/USB so you can connect to a PC straight away. I know this because I own a 4805 and have connected it to my PC to update the firmware on their site. I have had to buy a M1-DA to DVI adapter to get DVI from my DVD player.
  6. mavice
    mavice
    Dec 8, 2004
    399
    Midlands UK
    +16
    4805 connected to laptop via the M1-VGA cable
    cant seem to get higher res than 640x480 - Is this normal ?
    I set a custom res of 848 x 480 in NVIDIA driver (60HZ) but when I apply the PJ reports 640 x 480 and text looks chopped up - 640 x 480 is the clearest but I would like to output at 1:1 pixels.
    please dont tell me it only does this via DVI as my laptop does not have DVI output (and obviously cant be upgraded) :rolleyes:
    cheers
  7. mavice
    mavice
    Dec 8, 2004
    399
    Midlands UK
    +16
    uppy
