Connecting an external HD to an XBOX
Discussion in 'Xbox Forums' started by ibster, Dec 20, 2006.
  1. ibster
    ibster
    Aug 7, 2002
    335
    Coventry
    +12
    Has anyone tried this, i have an external Western Digital My Book HD which i want to try and connect to the XBOX, has anyone tried this ? Ive found a XBOX Controller to USB lead which should enable connectivity, would there be an issue with drivers etc or should all external Hard Disks work ?
    thanks
  2. scumball
    scumball
    Jan 12, 2004
    6,534
    Harrow - London
    +452
    I don't think any work... The drive would have to be formatted as FATX for one thing - how would you do that?
  3. ibster
    ibster
    Aug 7, 2002
    335
    Coventry
    +12
    The drive is already formatted to FAT32, what is FATX ?
  4. scumball
    scumball
    Jan 12, 2004
    6,534
    Harrow - London
    +452
    FATX is the file system used by an XBox...
  5. triplea4uk
    triplea4uk
    Jan 12, 2002
    2,018
    48
    Northants
    +85
    Only way it will work is if you have installed linux on your XB.
    If you want access to the drive just set it up as a network share when it's plugged into PC XB will then see it.
  6. scumball
    scumball
    Jan 12, 2004
    6,534
    Harrow - London
    +452
    But you can't load games and homebrew on it...only useful for streaming media using XBMC really. Best to fit a new bigger HDD in the XBox itself or you could get an Xtender case and fit a couple!
