Connecting an amp to a VERY old tv - is it possible?
Discussion in 'Cables & Switches' started by Tejstar, Jun 11, 2004.
  1. Tejstar
    Tejstar
    Dec 4, 2002
    22,873
    London
    +1,131
    I want to connect an integrated amp to a very old Toshiba set, the 285T8BU, a 28" 4:3 bought in 1990. I just don't know whether it is possible as it has no component, s-video or composite sockets.
    What it does have however is the following:
    1 scart socket
    1 S-VHS video socket
    2 S-VHS audio sockets (Left/Right)
    The tv is still in great working order and I don't have the funds to buy a new one just yet, so I was wondering whether there was a way around the problem? :confused:
    Any help would be much appreciated.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    2 possibilities:
    * The scart socket may carry the audio out signal, in which a suitable cable shouldn't be too hard to find.
    * If there's a headphone out socket you can route that into an amplifier.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,873
    London
    +1,131
    I'm a bit confused :confused:
    Do I need an audio signal to the amp, or a video signal, or both?
  4. Tejstar
    Tejstar
    Dec 4, 2002
    22,873
    London
    +1,131
    Also, is the s-video socket the same as a s-vhs video socket?
  5. diabolik
    diabolik
    What are you trying to acheive??
    a. listen to your TV sound through the amp OR
    b. feed the video from other sources through the amp into the TV?
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    As with diabolik, what exactly do you want to do?
    As far as you should be concerned, SVHS and S-Video are the same thing. Your TV will also have a composite video input as part of the scart socket.
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,873
    London
    +1,131
    Sorry guys I haven't been clear.
    What I'm trying to do is to have the tv connected to the amp to utilise the external speakers I have i.e. not the tv speakers. Judging by your reply does this mean I only need a video signal from the tv to the amp?
  8. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,554
    Somewhere in South Yorkshire
    +6,053
    You need an AUDIO (sound) signal from the TV to the amp.
    You may well get this from the SCART. Failing that (as stated) you can use the headphone outlet if it has one.
  9. Tejstar
    Tejstar
    Dec 4, 2002
    22,873
    London
    +1,131
    Would I be able to use the S-VHS audio sockets (red & white (L&R)) to feed the audio or would it be best to go through the scart?
    :confused:
  10. diabolik
    diabolik
    I would guess that the scart connection is OUT not in so that would be useless.
    If there is a red and white RCA audio connection out of the TV I'd use that.
  11. Tejstar
    Tejstar
    Dec 4, 2002
    22,873
    London
    +1,131
    Ok I'll give that a try!
    Cheers diabolik :thumbsup:
