Connecting amp to comp
Discussion in 'Cables & Switches' started by UnNaturo1, Jan 10, 2005.
  1. UnNaturo1
    UnNaturo1
    Hiyas,
    I want to connect my comp to my amp.
    I am playing mp3's and mpegs and the distance between the comp and amp is around 15 metres.
    I have used cheap rca leads in the past with significant deterioration in the quality of the music. i have a small minisystem right next to the comp...quality is ok...in the lounge..through the 15 metre rca lead, the sound is at least 1/2 volume.
    I have bought other cheap cables just in case the ones i have are faulty with no change.
    I can use both optical and digital coaxial as well (soundcard supports these)
    Any advice is welcome :)
