Connecting advice
Discussion in 'Cables & Switches' started by Olly_K, Jul 24, 2002.
  1. Olly_K
    Olly_K
    Jul 21, 2002
    16
    warning.....NEWBIE ALERT ! ! !
    Here is my problem.
    Just brought a Pace DTVA (which is brilliant, I recommend it to anyone!), but it only has a scart socket on it. What I would like to do is get component RGB out of this, to go into my Yamaha AX620 amp and then out to my plasma all via RGB.
    Can I plug my pace scart socket into a converter box to get RGB and also the two audio channels ?
    And also, just brought a sony dvpns-700 DVD player, and that has RGB via scart, again can I buy a scart to RGB lead to go into my amp or am I completely buggered ?
    If both of these are possible, where can I get such leads ?
    many Many thanks for your help in advance !
    Olly
  2. Olly_K
    Olly_K
    Jul 21, 2002
    16
    can NO ONE help me ?
  3. Jase
    Jase
    Mar 16, 2001
    10,722
    United Kingdom
    +2,491
    Have a look at this thread re RGB converting Here
    Probably answer your queries for you.
