kalelzkryptonite
Hi All, I had a question regarding sub woofer connections and hoping to get some answers so that I can clarify my understanding.
What I am struggling to understand is how to connect an Active powered Speakers to an Active Subwoofer, in a case where the active speaker doesn't have a sub out. Please note I don't want to use an AMP or a Receiver as I have no space. I need my TV sound to drive the system.
Can I provide the sub woofer with Line level inputs from the TV directly and then have a line level out to my active speakers from subwoofers? Will that setup work?
1. I want to pair the following models if that helps in answering the question -
Active Bluetooth Bookshelf Speakers D300 - Swans Speakers + SB-1000 Pro
The above sub has both line level Inputs and outputs.
So my TV ( LG OLED B8 ) connects to the Subwoofer's Line Level Input
Line level out on subwoofer to (Inputs on Swans bookshelf speakers ).
2. How about if I want to connect a sub with no Outputs like this one?
In this case can i use a Y splitter from TV out to connect to both speakers and my subwoofer inputs?
Hope this is enough information to get some inputs/suggestions, any help is appreciated and apologies if it made no sense
