connecting a Z2 to a dvd. Help please
Discussion in 'Cables & Switches' started by davyb, Jan 19, 2004.
  1. davyb
    davyb
    Hey guys, I have a Z2, Skyplus box and a marantz 4100 dvd player.I have used s-video to connect the pj and the skyplus. I need to connect the dvdplayer to the pj, but it doesnt have component video. It has two scarts only. Can i use the scart to RGsB cable to connect them. Does anyone know if this will work. There are two advertised on www.keene.co.uk but i am not sure if they will work. Can someone take a look and give me some advice to save me getting the wrong one, or any ather way around this. The two product codes on Keene are kld162 or sbb75.
    Thanks, Davyb.
  2. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Do a product search on Keene for SBB92S
    This works. I use it for Sky digibox RGB out to Sanyo Z2. Have also tested it on DVD.
    Connect to DVI using VGA/DVI converter
