Connecting a Xbox or PS2 to TFT screen.
Discussion in 'Cables & Switches' started by loafer316, Aug 4, 2002.
  1. loafer316
    loafer316
    Hi there.
    I've bought a TFT screen for my PC which has a DVI and the usual VGA/analogue connections...i'm going to use the DVI input for the PC and was wondering if i could possibly use the the other connection for a direct link to an xbox or PS2?
    Does anyone supply a lead that can connect and of these two consoles to the TFT w/o going through the comp?
    Will i be able to get an RGB connection?
    where can i buy such a lead.
    THXS for all your help
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You need a converter to run into the VGA port, the pro-v is in power buys for £125. That's quite a bit on the price of a console...
  3. loafer316
    loafer316
    yeah that is quite costly!..i thought there might have been a cheaper switch box of some sort...
    have you a link for power buys?
    thxs
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
