L
loafer316
Hi there.
I've bought a TFT screen for my PC which has a DVI and the usual VGA/analogue connections...i'm going to use the DVI input for the PC and was wondering if i could possibly use the the other connection for a direct link to an xbox or PS2?
Does anyone supply a lead that can connect and of these two consoles to the TFT w/o going through the comp?
Will i be able to get an RGB connection?
Plus as i havn't bought any yet...what console would you recommend...and more importantly where can i buy such a lead.
THXS for all your help
