Thanks for the reply
I already new that the Cam was supposed to be Video in (One of the reasons for buying it), but when you look in the Index it does not mention it.
The only diagram I could find in the Manual was one showing the Signal direction as 'Out' only
I am also using a proper Scart connector with all the pins connected and a Video in/out switch on it, so that I know the signal should be coming out
and I am plugging the Supplied CamCorder Phono's into that.
Then I thought it was time to post...
I will check the 'pressing the record' button, when I have it connected to the Video Player.
And will also check the manual again tonight
--Roger (Who wishes he had bought a PC330 now
1megapix CCD for Video is not clear enough
