Connecting a Toshiba 36ZP18P to a Yamaha AVSX 80 Home cimena kit
Discussion in 'Cables & Switches' started by Mike.j, Dec 14, 2002.
  1. Mike.j
    Mike.j
    I have connected the DVD to the amp/receiver which works fine, however I do not seem to be able to pick up the TV through the amp.
    I have a scart going from the DVD to the TV, however I am unsure how to get the correct audio input into the amp from the TV.
    Any help appreciated....
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Two options:
    1. Assuming you are using Sky Digital or some other form of set top box for TV viewing, connect a pair of RCA Phono Cables from the set top box audio outputs to the Amp TV (or AUX) audio inputs. Select the appropriate source on the AMP and make sure it is set to Analogue (not digital).
    OR
    2. Connect a pair of RCA Phono Cables form the TV's audio outputs (at rear of set) to the Amp's inputs as mentioned above.
