3t3p
Established Member
I've decided to go integrated in conjunction with my AVR for stereo music duties, so I need an amp with HT Bypass.
The Yamaha AS1100/2100 have really caught my eye but yet to audition them. They have a version of HT Bypass.
Unfortunately you can't connect my BK XXLs400's to the Yamahas via high-level as they are floating circuit reference amplifiers and speakon neutrik connection is therefore compatible.
The A1100 manual suggests to connect your active subs via L & R RCA jacks, which is fine, except I will then use up the R (mono) RCA jack on the XXLs400 which currently is plugged into the sub-out of my RX-A3070 AVR.
So i'm really stuck, my back up plan is the Arcam SA20 which is a traditional earth-reference amp but I know the Yamaha is gonna be great.
Yeah I really need to run subs though for stereo, it's just what I believe
Would I maybe run the front L & R speakers full range from the AVR (i.e. without 80hz cutoff) and have bass for movies then come out of the Yamaha integrated via the R & L RCA pre-outs and into the subs?
Any ideas?
Any ideas?
