Connecting a SACD player to an amplifier
Discussion in 'AV Receivers & Amplifiers' started by pend1711, Feb 6, 2009.
  1. pend1711
    pend1711
    Dec 26, 2008
    48
    Westhoughton, Lancashire
    I have a Yamaha A2070 amplifier and wish to connect to it my SACD player to provide the best 5.1 surround sound as possible. It seems to me there are 2 options and I would like some advice as to which is best.
    I can either attach with 2 phono cables and allow the amplifier to send the signals to the 5 speakers or I can use the 5 phono 5.1 connections from the SACD player to the 5 phono inputs on the amplifier.
    Is there any advantage or better quality with either option.
    I also have a DVD-Audio player which I also want to connet in the same way - I appreciate I will need a rather expensive audio switch for that.
    Thanks for any help given.
    Andrew
  2. easyshas
    easyshas
    Nov 19, 2005
    173
    camberley
    +14
    I would connect it to the dedicated 5.1 inputs on your amp as this will give you the dedicated 5.1 mix if available on the SACD disk. Using the 2 phonos will only give Dolby Pro Logic ii which is not a true 5.1 signal.
    Regards.
  3. IAN P
    IAN P
    Dec 11, 2002
    8,285
    +1,042
    Zektor make the dual 5.1 analogue switches.As you stated they're not exactly cheap,well,cheaper than buying a new amp i suppose.
  4. missinglink
    missinglink
    Apr 12, 2008
    248
    28
    +43
    The 2 phono connection will not give you Dolby Pro Logicii ; you will get a conventional stereo signal BUT your amp can create a pseudo-surround signal from it by applying a DSP algorithm such as Dolby Pro Logicii or DTS Neo 6.
    I take it the DVD-A player doesn't handle SACD's too?
  5. Steeve24
    Steeve24
    Nov 25, 2008
    125
    +8
    Just jumping in here, the amp doesn't have an 5.1 inputs only standard analog:
    ...although if I read this right it can be converted:
    DSP-A 2070 UPGRADE
  6. IAN P
    IAN P
    Dec 11, 2002
    8,285
    +1,042
