Connecting a RGB SCART to a PLASMA
Discussion in 'Plasma TVs Forum' started by highlander_777, Aug 28, 2004.
  1. highlander_777
    highlander_777
    Apr 4, 2004
    216
    I have a Sony Plasma and a SKY + Box
    Now, if I connect the two with a cheap scart I get pic and sound.
    However, when I connect a RGB QED SCART cable (£50) cable, I get a good pic but no sound!!. I note that the cable does have a plastic arrow with RGB written on it, so I have tried it both ways. I either get no pic, no sound or just pic, no sounds
    Any thoughts :lease:
  2. Mr Hoppy
    Mr Hoppy
    Jan 18, 2004
    Just a thought...
    Q.E.D. produce a scart cable with just the RGB video/aspect switching wired, in order to (in theory) maximize the image quality.
    Could you have been supplied with one of these rather than the fully wired version?
  3. highlander_777
    highlander_777
    Apr 4, 2004
    216
    I suppose I could have. It was connected up before to the TV and DVD for enhanced pic quality. so I suppose I need to a buy a new SCART ;-(
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    Hello Both
    QED have 'RGB Only' and 'Fully Wired' SCART cables - the 'RGB Only' cable wont transmit Sound (or Wide Screen Switching info); and keep in mind in the right system the Fully Wired wont look as sharp as it uses lower spec cable.
    Is there no option for an additional set of audio cables between your Digibox and TV?
    Best regards
    Joe
    PS I'd also confirm your actually getting RGB to your TV - you need to ensure the Digibox so set to output RGB and the TV is set to Receive/Display RGB!
  5. Mr Hoppy
    Mr Hoppy
    Jan 18, 2004
    Joe,
    Are you sure the RGB only cable doesn't transmit the w.s. switching signal?
    If so, I'll have to change my plans, as I was going to buy a couple to connect my digiboxes!
    Cheers...
