Hope someone can help, I've been trawling these forums for hours and I've reached a point where I'm getting more confused, not less.
I'm trying to connect a ps3 to quite an old Optoma projector- EP756. I picked the projector up dirt cheap from Ebay- it plays 720p films beautifully from my PC, but will only connect to the ps3 in standard definition, which looks terrible. The projector doesn't support HDCP, so I've concluded that I need an HD-Fury HDCP stripper/converter thingy to make it talk to the ps3.
I'm just concerned about the resolutions not being compatible, and about spending £50 on something that might not work.
Here's a bit of the spec for the projector:
Aspect Ratio 4:3 (Native), 5:4, 16:9
Resolution (Native / Max) XGA (1024 x 768) SXGA (1280 x 1024)
Video Compatibility NTSC (M, 4.43, 3.58), PAL (B, D, G, H, I, M, N),
SECAM (B, D, G, K, K1, L), HDTV (480i, 480p, 576i,
576p, 1080i, 720p)
and the inputs:
1 x VGA Connector
1 x DVI Connector
1 x Audio Mini Jack 15pin D-Sub
1 x Audio Mini Jack DVI
1 x S-Video Mini DIN
1 x RCA Composite
All I can find out about the ps3 is that its resolutions are 1080p, 1080i, 720p, 576p and 576i.
If it is compatible, does the HDfury plug in at the projector end- so could I also get it to talk to my Humax PVR, or would I need two of these devices at the input ends?
As you might have guessed, I don't have much an idea what I'm doing, so any help would be much appreciated. I'm new to this- watching films on a 3.0m screen has been a revelation, but I'll not be happy 'till I'm sat in front of it playing Wipeout in a half decent definition.
Ta in advance
576p, 1080i, 720p)
and the inputs:
1 x VGA Connector
1 x DVI Connector
1 x RCA Composite
Ta in advance
