connecting a projector to sky
Discussion in 'Cables & Switches' started by robertjohn, Aug 9, 2004.
  1. robertjohn
    robertjohn
    Sorry if this has been covered before
    I am a bit of a novice so any help would be gratefully received..I am presently watching sky via a projector ,,connected with a with the yellow video cable attatched to a scart converter as sky is not s video compatable...the picture seems ok but could be better for watching sports,,, Any advice on getting the best picture available?
    I have seen a box that converts sky to s video would anyone recommend this type of connection?
    the pj I have is a Mitsubishi hc3
  2. cablecar
    cablecar
    Nov 13, 2002
    304
    Wellingborough
    +10
    I currently use a Keene Syncblater 10m scart to 5 phono plugs (RGB) and the picture is very good, you can also get scart to VGA version.
    I have also tried the RGB to S-video converter and that works Ok but not as good as the syncblaster.
    I have that converter if you are interested in giving it a try.
    Cablecar
