Connecting a Pioneer 575 to a Panny PW6?
Discussion in 'Plasma TVs Forum' started by Moo242, Aug 2, 2004.
  1. Moo242
    Moo242
    Currently got the above DVD player (along with some Mark Grant component cable) and was thinking about the PW6.
    If I was making a shopping list of any extra bits (leads, converters etc) to buy to get the very best PQ (progressive or otherwise), what should I have on it?
    Please bear in mind, I'm a bit plasma-tech' ignorant at the moment, so be gentle :blush: . Also, I'm only really concerned with the ultimate DVD connection (it will have a skybox in there but thats only so the missus can watch wife swap :rolleyes: )
    Finally, this seems like a very good price (am I missing something?)
    http://digitaldirectuk.com/products_moreinfo3/index.asp?product_id=1527
    Cheers guys :smashin:
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It's a blinding price, apart from the fact stock is due 'mid august' so don't hold your breath. Likely this does not include any video boards, nor a wall mount. Connecting the DVD is easy, the sky box a bit less so, you've got some decisions to make. Do you have a sound system, if so what amp? does it switch component video? You could connect both to the screen via a component switching amp with no video board, just a 3-phono to 15pin sub-D cable and a JS RGB to YUV converter for sky. Excellent picture for both too. Check that panny price when you've added the bits you need, see if you might prefer a scart board for the screen to make sky easy to connect without an AV amp, or for better picture there are other ways too.(scart input looks a bit soft on the panasonic). With a wall mount, some cables and accessories and a video board, you might well find a better deal close to this spot.
