connecting a new device to my pc
Discussion in 'Desktop & Laptop Computers Forum' started by kronenbourg316, Mar 10, 2005.
  1. kronenbourg316
    kronenbourg316
    Oct 12, 2004
    142
    +4
    hi
    can anybody help me out here
    i have bought a new dvd-rw drive for my pc and have no way off connecting it to my motherboard , the motherboard i got has 2 IDE connectors 1 is for my cd&dvd drives ansd the other is for my HDD
    now i got this new dvd-rw drive and havent got a ide cable i can connect it with
    is there anyway i can connect this drive without having to take out one of my drives or get a new motherboard
    many thanks
    Chris
  2. mrmoo
    mrmoo
    Jan 10, 2005
    517
    +19
    Do you know about slave/masters? If you have two IDE connectors on the motherboard you can connect upto 4 IDE devices. What have you got connected at the moment?
  3. kronenbourg316
    kronenbourg316
    Oct 12, 2004
    142
    +4
    i dont know a lotabout slaves/masters
    my motherobard has got 2 IDE slots
    IDE1 ( connects 2 HDD)
    IDE2 ( connects 2 cd/dvd drives)
    just need a way of connecting my other drive
  4. Pack Dude
    Pack Dude
    Feb 6, 2002
    877
    Lost In Space
    +98
    Why not take out your CD and DVD drive? Every DVD writer ive seen will play DVD's/CD's and also write to both.
  5. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    why would you want or need 3 cd/dvd devices. If you do hvae 4 IDE devices already then simply remove one of the current cd drives. The new dvd should do the same as the old one you remove
    Dave
  6. mrmoo
    mrmoo
    Jan 10, 2005
    517
    +19
    You can't if you have 2 hard drives and 2 optical drives. You must be clearer, what is connected? If you only have 1 optical drive, then connection is simple. List the drives you have connected.
  7. kronenbourg316
    kronenbourg316
    Oct 12, 2004
    142
    +4
    the reason i want 3 drives is that my dvdrw only writes at 16 speed and my new cdrw writes at 52 speed therefore i am saving time
    greedy i know :rolleyes:
  8. kronenbourg316
    kronenbourg316
    Oct 12, 2004
    142
    +4
    IDE 1 Has 160gb & 80gb HDD
    IDE 2 Has DVD-ROM & DVDRW
    got an extra CDRW to fit
  9. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    to be honest I dont think you can do it. You may have to biter the bullet and remove one of the older drives.
  10. mrmoo
    mrmoo
    Jan 10, 2005
    517
    +19
    The only thing to do is make one of the drives a USB device. You maybe able to find an external 5.25 drive bay with IDE interface. Or does your motherboard have SATA ports?
  11. DaveP
    DaveP
    If you have a spare PCI slot you could buy another IDE controller card. They cost about £15 iirc.
    You could then have up to another 4 devices, assuming your PSU can support that lot!
    Dave
  12. kronenbourg316
    kronenbourg316
    Oct 12, 2004
    142
    +4
    the EIDE card is a good option , i have just had a look and they are under £10 on ebuyer
    thanks to everybody for there advice :thumbsup:
  13. mrmoo
    mrmoo
    Jan 10, 2005
    517
    +19
    A solution in just over an hour, not bad.
