I have a Marantz tuner/amp that has digital inputs. I have a Phillips TV with SPDIF outlet on the side, a female connection that takes a small bayonet plug on an optical cable.
Not being technical but thought to be not too stupid I arranged the old TV with analogue connectors to be connected to the Marantz and a speaker specially adjusted so my 'hard of hearing' wife could here TV sound properly from a speaker perched on her shoulder. Worked a treat.
I want to replicate that but have to do it digitaly/Optically.
I have a 10 metre Optical cable but it has similar connectors at both ends. I need a converter for the TV end so I can connect to the TV. The other end is right for the Hi-Fi.
Either I have been told wrong, or people just cannot understand what I want!
I have been provided with 2 different converters. Not what I want, they fit over the cable plug but all they do is replicate the hi-fi end of the cable slightly adjusting the size of the male connector and also, in any case ,not long enough and too small a diameter plug.
Sorry about the lengthy description. I tried to anticipate questions.
What do I need? What do I call it so I can be understood? Where would I get it?
Help please......
Help please......
