Connecting a DVD to an AV Receiver?
Discussion in 'Cables & Switches' started by Algor777, Feb 2, 2005.
  1. Algor777
    Algor777
    I have connected a Toshiba SD340E DVD player to a Denon AVR-1705 receiver using component cables. My problem is when I play a DVD I can hear the sound but no picture.
    I have used a S-Video cable to send the output from the receiver to my TV because it does not have any components inputs.
    I have spent hours trying to figure out why but without any success. Has anyone got any ideas? By the way I am a newbie to AV.
  2. nwgarratt
    nwgarratt
    May 5, 2002
    26,402
    +2,858
    I be very surprised if the reciever can convert the Component to S Video.
    Most of the time it is the same format for both in and out (S Video in/S Video out).
    I would just connect a scart lead to the TV using RGB.
  3. Algor777
    Algor777
    Thank you. I will consider the options.
