Connecting A DVD Recorder
Discussion in 'Cables & Switches' started by mark67, Oct 30, 2003.
  1. mark67
    mark67
    I have bought the Sony RDR GX3 Recordable DVD. (Hope fully Friday).
    Trouble is I have now run out of coaxial digital input sockets on my Tag AV32.
    I have used them as follows:
    CD CD
    DVD Tag Digital Tuner
    LD Minidisc
    Synclink CD synlink
    I had refrained from using the Optical digital Inputs due to the (alledged) inferior sound.
    So it now looks as though I have got to use on of the optical inputs, I will put my DAB radio into that
    socket, so can you suggest a good Optical cable, are the ones on the AV32 Toslink connections?
    Is there any other way of connecting the DVD to the AV32? I do not have the 5.1 by-pass.
    At present my AV32 is having the 192/24 dac put in.
    Cheers.
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Nothing wrong with optical, try Chord or QED for decent cable, avoid cheap thin one though.
