Connecting a digital camera to a HD5
Discussion in 'Headphones, Earphones & Portable Music' started by Dokken, Jul 20, 2005.
  1. Dokken
    Dokken
    Oct 10, 2004
    81
    +5
    Can anyone tell me if you can connect a digital camera to the HD5 via the usb socket. Is the socket standard usb, or do you need an adapter like the ipod? As I would like to use the HD5 to back up pics on holiday etc.
    Haven't bought one yet but this my be the deciding factor!
  2. Mike_manchester
    Mike_manchester
    The supplied cable is standard USB type A male at the pc end and mini usb at the hd-5 end (cable is, incidently, exactly the same as my old net-md one)
    The mini-usb connector fits perfectly the digital port in my Canon 300D digital camera, tho i stress i havnt tried any transfers with it - but it fits perfectly.
    Problem is that mini-usb comes in identical 4 and 5 pin varients and i cant really tell which this is soooooooo.... good luck
  3. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,236
    +63
    Won't work as it's a USB client, not a host. There are potential workarounds, but if they don't work then you're left with a lemon. The iRiver H320, iAudio X5 (which is a USB2.0 host) and the iPod Photo (which has probably the widest range of fully tested cameras) would be a much better bet.
  4. HMHB
    HMHB
    Nov 11, 2001
    25,598
    Nottinghamshire
    +3,948
  5. Dokken
    Dokken
    Oct 10, 2004
    81
    +5
    Thanks for the advice, the usb bridge route might be the way to go. I do like the looks of the ipod, but battery life is so poor. So I looks like it'll be the HD5 as everything else in the house is sony, it'll keep the missus happy!
  6. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,236
    +63
    2 solid working days of listening is poor?!?
  7. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    Depends on your habits, I guess.
  8. Hrochnick
    Hrochnick
    Apr 28, 2005
    369
    Brno
    +9
    Compared to 4... yes.
