Connecting 360 wireless contrller to PC
Discussion in 'Xbox Forums' started by nelliemcnell, Sep 22, 2007.
  1. nelliemcnell
    nelliemcnell
    May 6, 2007
    38
    I have downloaded the drivers from MS and I plug my controller into the PC via the play and charge cable. Windows recognizes it and says it is working properly, how ever it is not being picked up as a game controller. Any suggestions, including, stop trying it won't work!!
  2. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    That is not going to work. You cannot use the wireless controller with a PC using the play and charge kit cable. If you want to use the wireless controller then you will need to buy the wireless reciever for it which costs £14.99. That plugs into a USB port on your PC and allows the controller to communicate with it wirelessly.
  3. nelliemcnell
    nelliemcnell
    May 6, 2007
    38
    Thanks. I knew about the adapter, I was trying to be cheap! I thought the play and charge cable turned the controller into a wired connection, it never occured to me that it was still connecting to the 360 wirelessly.
