Connecting 2 component cables
Discussion in 'Cables & Switches' started by Monkey Alan, Aug 4, 2005.
  1. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    629
    +39
  2. neil68
    neil68
    Aug 1, 2005
    13
    It won't cause any problems at all. I find a bit of electrical tape around the joint stops it coming undone or working loose!
    Neil.
  3. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    629
    +39
    Good idea, thanks! :thumbsup:
  4. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    Just bear in mind that this connector is almost definatly not 75ohm, and will be introducing an impedance miss-match. shouldn't really affect you that much, but this can affect video levels and above all, video quality. This would be a shame if you have spent out on expensive RCA cables.
    Something to keep in mind!
    Gareth.
  5. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    629
    +39
    How do you know its not 75ohm? Is there a 75ohm one I can get?
  6. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    Good question.... I dont know! Im sure they would be expensive to get anyway, judging by the price of 75ohm RCAs.
    I run BNCs with my componant cable... and 75ohm bnc couplers are easy to come by!
    I would suggest giving it a go for the sake of a £5er and see if there is any noticable difference with the extra join in the loop. The difference in your situation may be so small, it will no doubt be ok. YUV is a robust signal by design, and the main difference you would get (if any) is less detail with high end loss from the luminance signal, which is where all the detail is.
    Go "suck it and see"! :smashin:
    Gareth.
  7. Monkey Alan
    Monkey Alan
    Jan 19, 2005
    629
    +39
    Ok thanks, I had some bnc connecters come with one of my cables, I just need to get 3 female ones and I'll give it ago. :smashin:
  8. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    But remember, this will only be worth it of your 2 x componant cables are true 75ohm RCAs...
    Gareth.
  9. neil68
    neil68
    Aug 1, 2005
    13
    Surely, if you convert a phono to BNC add an inline BNC and convert it back again you will creat more resistance than if you just used the inline phono adapter???
    Neil. :confused:
  10. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    We are talking impedance resistance, Rather than what you are refering to!
    Also, Did you know that all video I/Ps have a 75ohm resistor actross the screen and centre conductor? (small bit of trivia) :)
    If the RCAs are 75 ohm, then all should be ok on a short run like this.
    Gareth.
  11. Zone
    Zone
    Jun 24, 2001
    6,747
    Barnsley
    +2,441
    No such thing! Cables yes and BNC's connectors as you have discussed previously yes! But RCA connectors no!
    The Canares that Mark uses in his power buy section are supposedly considered to come closest but RCA were never meant to be Video connectors!
  12. Member 34135
    Member 34135
    Those adapters will do the job but you can buy them much cheaper.
  13. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    To be honest, Im going by the "sales blurb" on the £30 RCA plugs which some people are claiming are 75ohm (Im not stupid enough to do it though), cheaper to buy BNC and RCA adapter @ £3 per end (If I had to pay at all! :rotfl: )
