Connecting 1803 to Toshiba 220 player
Discussion in 'Cables & Switches' started by jonnow99, Aug 28, 2003.
  1. jonnow99
    jonnow99
    I am thinking of getting a Denon 1803 Amp to connect to my Toshiba 220e but am not sure of which interconnecting cables I need. I have already invested in some QED Silver anniversary and Miro cables for my new Kef 2005.2 speakers so preferably would like something that would really get the most out of the cables I already have.
    Any help much appreciated.
    Jonno
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    You'd need to buy a Digital Coaxial or Optical cable - preferably one of reasonable quality.
    Most eletrical retailers will be able to sell you one of sufficient quality.
    This cable will run from the digital output at the back of your Toshiba DVD player to the corresponding input on the back of the AVR1803 amp.
    I can't imagine you'll need to spend more than £20-30 on a cable.
  3. Dominic
    Dominic
    Mar 2, 2001
    288
    Essex
    +6
    jonnow99
    i have those 3 items, 1803,tosh220 and kef mk2 eggs
    tosh is connected via optical to 1803 and using Svideo for picture, plan is to run componant to the 1803 and then out to the projector. But for you it depends on what your outputing to. If a TV then use the sfid, if plasma/pj use componant. your choice.
  4. Help
    I have the same setup too, and I went with a 1m Scorpion coaxial cable.
  5. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Just wondering what you thought of the Scorpion in your setup. Do you have any other standard phono cables to compare with?
  6. Help
    No I haven't. I picked all elements of my kit from recommendations from users on this and other sites. People seemed to be impressed with the Scorpion cables so I opted for them, both to connect the DVD to the amp, and the amp to the sub. The customer service is fantastic also.
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,388
    I'll go along with the recommendations for Scorpion cables. I've got coax, sub & component cables.
    Great quality cables at realistic prices. www.scorpioncables.com
    Mark.
  8. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
    Whether you would notice the difference between a 50p phono cable and an expensive one for digital coax is debatable on some systems. I know that on some higher end stuff people have experienced a definite increase in performance with the better quality ones. Just interested to see if people could hear an obvious improvement over a cheap cable in a system such as that mentioned above.
    BTW i am referring to the Denon 1803/Tosh/KEF setup.
