Connected to router but no Internet
ajever01
We recently moved out router from inside a cabinet to on top of it for better wireless reception but once we plugged everything back in, none of our computers were able to connect to the wireless signal. It picks up the signal but has the "No Internet Access" label. My laptop is an HP and the router is a D-Link WBR-1310. I am able to access the internet when connected straight to the modem. I have tried power cycling it, diagnosing and repairing the connection through the windows system, but nothing has worked. HELP!
Below is the ipconfig/all results when connected to the router.
C:\Users\Austin>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Austin-HP
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Broadcast
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter
Physical Address. . . . . . . . . : 16-DE-2B-71-6C-F4
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 74-DE-2B-71-C9-EC
Ethernet adapter Local Area Connection 2:
Description . . . . . . . . . . . : PdaNet Broadband Adapter
Physical Address. . . . . . . . . : 00-26-37-BD-39-42
Wireless LAN adapter Wireless Network Connection:
Description . . . . . . . . . . . : Atheros AR9485 802.11b/g/n WiFi Adapter
Physical Address. . . . . . . . . : 74-DE-2B-71-6C-F4
Link-local IPv6 Address . . . . . : fe80::59f2:325:d4c9:9fed%13(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.101(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, July 16, 2012 7:43:20 PM
Lease Expires . . . . . . . . . . : Monday, July 16, 2012 10:43:20 PM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 242540075
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-16-4A-F7-33-74-DE-2B-71-6C-F4
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : zoominternet.net
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 2C-76-8A-E6-7C-AD
Tunnel adapter isatap.{F4397022-1A39-4C21-84D4-49C7949B2D77}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.{0FC0C6AD-4BAF-4E7E-A25F-37B9043A345D}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{EA127D48-EC1E-4E42-AF71-87A4B4CC0F32}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Tunnel adapter isatap.{EA5299B2-CFCE-45B6-BD57-8A271ABC8F75}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter isatap.zoominternet.net:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
C:\Users\Austin>
Here are the results when connected straight to the modem.
EndlessWaves
I had this on my old D-link, despite apparently being connected and having been assigned an address the router was blocking access because I'd actually mistyped the wireless password.
ajever01
I wish that was the case for me...I've been trying to fix it constantly with no luck. Unfortunate timing because I desperately need it for my work.
sergiup
You seem to be getting the same IP (and gateway and DNS settings) when connected directly to the modem (by network cable?) as when you are connected via WiFi to the router, which doesn't look right.
Also just noticed that both copy/pastes you've done specify WiFi interface IP's etc only - how are you actually connecting and to what..?
Neorion
If you logon to the console of the router there should be a diagnostic page somewhere. See if it actually connected to the web.
You should be able to ping from the router.
I dont see it being an issue getting the same IP on wifi and LAN. The router will have seen that the IP table has that address free and used it next.
Neorion
here ping this from the router
212.58.241.131
Thats the bbc address if you dont get a reply, time to check all the connections from the wall. If its ADSL move you router to the master socket, this should have a plate you can remove.
Behind that you will see a phone connection, skip using the filter and plug the router straight in. If that works your connection is ok and its probably a filter or extension issue.
be aware, when you remove the faceplate it disables all other phone points in the house but its only for testing so just plug it back in when done.
sergiup
Maybe, however if you look at both things the OP pasted here, they're identical, same lease time, same IP's, same WiFi interface..
maf1970
With the modem and router connected did you try via wired ?
:lesson: Also your post has a big mistake in it.
It looks like you have cut and pasted the same thing twice.
Give away is times are identical.
I suggest you try logging into the router GUI (while connected to modem) and have a look at the TOOLS on the top horizontal menu then choose SYSTEM CHECK on the vertical menu.
This should tell you if you are connected. There is also a ping facility on the same page to test connection.
If it shows you are not connected then go to STATUS on the horizontal menu and then DEVICE INFORMATION on the vertical menu. In the WAN box if there is release and renew buttons showing then click release first,wait a while then click renew then test connection again from ping facility on other page.
EndlessWaves
Well, it won't take long to go into the router, check that the password is what you think it is, and then reconnect and manually retype the password. No point in assuming anything when you can eliminate it quickly.
🎬 The Top 20 Most Anticipated Movies of 2024
Back
