Connected on wireless network but cannot load webpages
PrPrO
Hello, I am new on this Forum and I think you could help me out :)
I have the network signal strength booster and it sees mine network, the signal is excellent, connected to the internet and everything is great, but i can not open anything. Can't open any browser.
The problem is on the windows xp.
I have mini notebook that is connected wireless and everything works fine. 2 computers are connected with cables and the last one is connected with usb stick.. so, wireless again :)
Here is the ipconfig/all from the problematic computer:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Danko>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Radiona
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Realtek RTL8139 Family PCI Fast Ethe
rnet NIC
Physical Address. . . . . . . . . : 00-0E-2E-29-BE-F3
Ethernet adapter Wireless Network Connection 2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek RTL8187 Wireless 802.11b/g 5
4Mbps USB 2.0 Network Adapter
Physical Address. . . . . . . . . : 00-0F-04-B3-37-8C
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.1.105
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
I set the IP address and everything else manually
And here is the ipconfig /all from one of the working computers:
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Matija>ipconfig/all
Host Name . . . . . . . . . . . . : Matija-PC
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 00-1A-4D-4F-53-1A
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::943f:2821:def4:d307%23(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.102(Preferred)
Lease Obtained. . . . . . . . . . : 31. srpnja 2012. 7:08:22
Lease Expires . . . . . . . . . . : 6. rujna 2148. 22:00:57
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 184556109
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-29-29-67-00-1A-4D-4F-53-1A
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Hamachi:
Description . . . . . . . . . . . : Hamachi Network Interface
Physical Address. . . . . . . . . : 7A-79-05-5C-9A-1E
IPv6 Address. . . . . . . . . . . : 2620:9b::55c:9a1e(Preferred)
Link-local IPv6 Address . . . . . : fe80::8cdb:b1bc:bf33:c14b%27(Preferred)
IPv4 Address. . . . . . . . . . . : 5.92.154.30(Preferred)
Subnet Mask . . . . . . . . . . . : 255.0.0.0
Lease Expires . . . . . . . . . . : 31. srpnja 2013. 7:10:29
Default Gateway . . . . . . . . . : 5.0.0.1
DHCP Server . . . . . . . . . . . : 5.0.0.1
DHCPv6 IAID . . . . . . . . . . . : 544897433
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter isatap.{B89F4B37-C79E-412E-9089-86ACF0AE8A89}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter 6TO4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
Tunnel adapter Reusable Microsoft 6To4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #2
Tunnel adapter Local Area Connection* 15:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #3
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fd:c6c:17e:a274:6fb2(Prefer
red)
Link-local IPv6 Address . . . . . : fe80::c6c:17e:a274:6fb2%25(Preferred)
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 17:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #4
Tunnel adapter Local Area Connection* 18:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #5
Tunnel adapter isatap.{2C5A3112-FD22-48A6-93CD-35D81F43D5C1}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
C:\Users\Matija>
This one is wired to the router using Windows 7
Here is the connection test from Wi-Fi Inspector:
In the router setting it says that the problematic PC is connected:
Radiona is the problematic computer, War_Machine is one of the 4 other working :D
I can access the 192.168.1.1 setting from the problematic PC
My service provider is T-Com
Broadband connection: ADSL
Modem is: Gigaset SE555 WLAN dsl
Thank you in advance!
MarkE19
Do you have MAC address filtering enabled for your wireless connected devices? If so have you added the laptops MAC address to the allowed list?
Mark.
PrPrO
To use the OpenDNS I just have to register and type preferred and alternate DNS server?
will try that in a moment if that is so.
The password is correct.
EDIT: Oops. You're not using OpenDNS yet. :D
So.. neither googledns or OpenDNS are working
filtering in the 192.168.1.1?
MAC address filter is OFF
maf1970
Have you tested the problematic windows XP machine using a wired connection ?
If not, why not ?
PrPrO
I set to configure IP automatically, didn't help, removed the security on the network(no password) didn't help, manually configured IP after removing the password didn't help also...
I tried to connect it via the ethernet cable but still... I am connected.. can access the 192.168.1.1 but can't get any webpages to load
PrPrO
external IP like open DNS? i can ping 192.168.1.1, can ping some open DNS's i tried, liek googleDNS: 8.8.8.8 or 8.8.4.4 and some other open DNS, and i think i can ping the google ip adress but cant ping google.com
mickevh
When you try pinging (say) the bbc ("www.bbc.co.uk") does your problematic computer:
A) resolve the name to an IP address (regardless of whether ping replies or not)
B) get any replies to ping
This doesn't sound like a DNS issue, so don't bother with openDNS and the like for now. The results of A) will tell us whether this is DNS problem or not.
Have you got any firewall or anti-malware software running on the problem PC? It sounds more like that line of country to me.
Note that as a "security" measure many web sites these days refuse to respond to "ping" (though they should resolve,) However, at time of writing the bbc usually still respond to ping.
PrPrO
Here is the result of pinging:
C:\Documents and Settings\Danko>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Ping statistics for 192.168.1.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 3ms, Average = 2ms
C:\Documents and Settings\Danko>ping bbc.co.uk
Ping request could not find host bbc.co.uk. Please check the name and try again.
LJx
Why did you manually input the settings on the computer that doesn't work? why not do it auto like the others
mickevh
OK - that's a DNS issue.
So lets check that web browsing works:
On your PC that works, do that same ping of the bbc a note the IP address the the name resolves to. For example, on my PC at time of writing "www.bbc.co.uk" resolves to 212.58.246.94.
Take the IP address to you problem PC, open a web browser, the type "http:\\[IP address]" into the address bar and see whether the bbc's web page loads. (replace [IP Address] with the IP address of course. "http:\\212.58.246.94" in my example.)
PrPrO
I tried that and I can access the websites by typing their IP address
EDIT: It is obtaining IP address and DNS automatically
PrPrO
I set Win firewall to off, uninstalled Ad-watch Lavasoft, uninstalled nood32, and also uninstalled some p2p programes like limewrire, bitcomet and others
mickevh
Presumably that didn't make any difference.
It's a long shot, but check whether the DNS Client service on your errant computer is "started" and set to start up "automatically." (If you don't know how to do that, post back.)
PrPrO
Is that set where the IP & DNS of the computer are set?
properties, TCP/IP and that stuff?
if not, can you please explain how to "start" it up?
mickevh
On XP -
"Start" "run" and type "services.msc" in the run box & click OK.
In the list that opens up, (it's a list of all the "service" processes your computer can run - many of which are set up to start automatically when the computer starts up) somewhere is the "DNS Client." Have a look to see if it's "status" is "started" and it's "Startup type" is set to "automatic."
If not, double click it, change the "startup type" to "automatic" and click the "start" button.
PrPrO
Woohoo
I runned Malwarebytes and scanned the computer for malware
delete aprox. 15 fiels/folders and now.. INTERNET WORKS :D
Thank you everyone that helped me out solving out the problem
Thank you again
