Connect XBOX to 5.1 speakers
Discussion in 'Xbox Forums' started by harry66, Sep 9, 2003.
  1. harry66
    harry66
    Mar 20, 2002
    1,404
    Ilford
    +62
    I know there are a number of previous threads on this topic but none seemed to address my problem.
    I have a set of 5.1 speakers with built in amp. It has 5.1 phono input and a AC3 mini DIN input.
    Am I right in assuming there is no way I can connect my XBOX to these speakers?
    I dont have an AV amp or anything like that. The speakers are currently connected to my DVD player which has a built in decoder and the appropriate phono connectors
    Would I have to by a AV receiver or something. Sorry to be dumb but I am clueless when it comes to these things.
    Thanks in advance
  2. ZeroCool
    ZeroCool
    Yes!!!! Especially if you want both your DVD and the XBOX connected at the same time...
    An AC3 mini DIN connector? AC3 aka dolby digital aka dolby 5.1 is all the same. But I have never heard of a mini DIN connector...
    Zero Cool
  3. Iain Shields
    Iain Shields
    Oct 19, 2001
    786
    N.Ireland
    +3
    Mini DIN connector? If it's the same digital connection socket you'd find on a portable mini-disc or cd player for example then you should be able to do it, as you can get a little adapter to put on the end of an optical digital cable that fits it...
  4. harry66
    harry66
    Mar 20, 2002
    1,404
    Ilford
    +62
    It is a 9 Pin Digital DIN connector as used on the Cambridge Soundworks DTT3500 Digital Speaker system and a few others.
