Connect VCR to amp?
Discussion in 'AV Receivers & Amplifiers' started by mevetts, Aug 3, 2004.
  1. mevetts
    mevetts
    Oct 31, 2003
    439
    How do people generally connect their VCRs to their amps?
    Will amps 'convert' the sound into 5.1 from VCR?
    Thanks,
    Mark.
  2. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    923
    28
    London
    +25
    A prologic IIx amp will convert pro-logic from a suitable tape to 6.1. I think most people channel everything through the amp.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    an amp with logic 7 will make 7.1 or 5.1 from a stereo VCR /tape prologic 2 will give surrund sound. most VCR will have audio output, or use a scart break out cable
  4. mevetts
    mevetts
    Oct 31, 2003
    439
    Hi guys,
    Thanks for the replies. Mr Hornydragon sir, when you say 'audio output' do you mean stereo audio out. My VCR has these as I am running the stereo sound through my hi-fi.
    What is a 'scart break out cable'?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    MR??? DO hornydragons have gender????
    Yeah you just need to hook them into amp as you would hiFi and select the processing ode that please's you.
  6. mevetts
    mevetts
    Oct 31, 2003
    439
    Well.....thought I would be polite!
    Does the Pio VSX-C301-S support these connections?
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    What about video connections then? Does anybody use the in/out capabilities of their amp? Is it even useable?
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    yes the video switching on scart (forgot about that ) is very good, all you actually need is scart from VCR amp and scart from amp to TV!
    PS i was winding you....
  9. mevetts
    mevetts
    Oct 31, 2003
    439
    .....UP!!!!!! lol
    So I could run a scart from my VCR to the amp and then from them amp to the tv?
    What are your thoughts on the Onkyo TX-SR-500-E, seems a decent first timers amp!
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    cant do the scart thing with it! pio 301 and 500 are pretty much the only entry level amps that will! otherwise wiith the Onkyo etc need to use analogue stereo interconnects as explained above.
  11. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Not really. You can get some surround sound from stereo or DPL (Dolby Pro-Logic) sources though by using either DSP modes (that most amps have) or from more clever algorithms like DPLII(x), DTS Neo6, Logic7 (L7), CSS2 or whatever they are called.
    The ".1" is however usually only achieved by means of bass-management, i.e. the DSP does not create a discrete LFE.
    You can bypass the amp for video use (usefull if you want to use RGB as most amps do not switch that) and connect the stereo outputs to the AV amp. Else you would need Scart to RCA adapter cables, either terminating into composite + audio R&L (for standard VCRs) or S-Video + audio R&L (for S-VHS VCRs).
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Pio 301 will switch 3 scarts to TV RGB fullsupported so if going for that amp then best option is to go for scart.
  13. mevetts
    mevetts
    Oct 31, 2003
    439
    Thanks for the advice, but for some reason the Onkyo TX-SR500 is drawing me. It seems to have good enough specs? Any thoughts, suggestions or preferances?
    Cheers,
    Mark.
  14. SurferDude
    SurferDude
    I checked out the Onkyo's before ultimately buying my Marantz and thought they were a good little AV Receiver. The only obvious downside was the power drop when driving all 5 channels. But even so, they give a nice enveloping soundstage and the 601 that I was looking at even had multi-zone.
    As for the video through the amp question, I've decided to do this for my devices. Simple reason was that I only have one video-in on the TV but have 3 different video devices. So I take them all in to the AV Receiver then the one out from the receiver to the TV. I select the device I want to play on the receiver and don't have to worry about unplugging/plugging devices or manual selectors. Unfortunately, my TV only takes the single composite cable and not component so for me it was an easy decision. Had it taken component I would have probably driven it direct from my DVD/SACD multi player and not through the amp.. :)
  15. mevetts
    mevetts
    Oct 31, 2003
    439
    Thanks Surferdude.
    Narrabeen.......I'm an ex-resident of Manly!
    When you say there was a drop in power when driving all speakers are you still able to crank them up enough to get a loud sound? I don't miond it is not deafening (spelling!).
    Cheers,
    Mark.
  16. SurferDude
    SurferDude
    Mark,
    For most normal household applications the TX-SR501 will do the job, but it is an entry level receiver. If you want to know what its capable of you're best off dropping in to a dealer and have them demo it on a set of speakers you'd be happy to buy down the track. If you like the outcome, buy it!
    But be warned, they'll probably start walking you through your alternatives and you might catch the upgrade bug before you've even got that first receiver.
    IMO, you'd be pretty chuffed with the TX-SR501. Its not a powerhouse but it gives a nice enveloping soundstage and gets some pretty rave reviews from most of the mags. The sound wouldn't be deafening, but plenty load enough for most.
    P.S. Weather's a bit chilly in Narrabeen at the mo' at around 18C max. But even so, the surfs still great and I'm only 5 minutes walk from the beach. I can see Long Reef from the top deck of my house and its a pretty picture to wake up to every day :)
    Cheers,
  17. mevetts
    mevetts
    Oct 31, 2003
    439
    Thanks surferdude. I am very jealous, stuck in an office with miserable rain outside (and it's supposed to be our summer!).
    The receiver should fit the bill, so can't wait!
    Mark.
