Connect USB Flash Drive to Cyrus DAC?
Discussion in 'Music Streamers' started by Skyrider, Feb 15, 2014.
  1. Skyrider
    Skyrider
    Sep 2, 2007
    1,114
    63
    +186
    I have recently started listening to high-definition (high-resolution) music albums, which I have downloaded onto a USB flash drive.
    I am able to plug this flash drive directly into my amp & use its internal DAC. However, I'm pretty sure that the internal DAC is not as good as my Cyrus DAC X Signature, which I would like to use if possible.
    Does anyone know of any kind of adapter, or method, which would enable me to connect the flash drive to the Cyrus DAC (no kind of USB port on this one), without having to go so far as to obtain a dedicated streamer?
    Thanks...
  2. dean999
    dean999
    Jun 20, 2005
    1,402
    63
    +129
    Audio T sell the convertors i think
  3. Skyrider
    Skyrider
    Sep 2, 2007
    1,114
    63
    +186
    dean999: many thanks for your suggestion, which I've only just spotted.
    I haven't been able to find any kind of simple, cost-effective method of achieving this, although I have found a more expensive method:
    It's called a Cyrus Stream X Signature streamer, cheap at £1250 :laugh:
