Connect to Plasma
C
carolepat
I have a Harsper HP-4200M Plasma, and I want to be able to use the scart RGB ouput from my Sky+ box. Unfortunately the scart on the plasma does not take RGB, I have also tried a Syncblaster cable and that also would not work with my Plasma.
Any ideas?
C
carolepat
The plasma will accept RGB but only on the 15pin D-SUB for connection to a PC, and on the component DTV YPbPr for connection of a DVD/HDTV.
As already mentioned I have tried a syncblaster cable to the 15pin D-SUB, but the horizontal frequency on the plasma is too high.
Cheers.
choddo2006
yeah a syncblaster won't work - that RGB is really just VGA, not RGsB which is what you get down a SCART lead. The syncblaster adds horiz sync but can't match the frequency as you found.
I'm astonished any TV built in the last 15 years, let alone a plasma, would not have RGB on SCART. But, erm, it's "one of those" Korean jobs I think?
The Sky+ box gives a pretty good s-video signal, that's probably your best bet unless you want spend serious money.
