Treadway1
Hey guys,
I’m converting my garage to an office and have decided to run a 5.1 speaker cable setup, just in case we ever want to use it as a cinema room. As part of that, I’ve run a single RCA cable behind the stud walls from where the amp will be to where the sub will be located.
I’ve bought soldered faceplates for all the cables including the main one that’ll sit behind the receiver.
My question is: if I cut the jack plug off the end of the RCA cable, how many cables will I find inside and which ones do I solder to the back of the faceplates sub connector?
I’ve tried Googling it but strangely can’t find anything specific to my situation and don’t want to go cutting the end off to find there’s another way to do it.
TIA
TIA
