Connect question
Discussion in 'Nintendo Forums' started by pauloregan, Jun 13, 2005.
  1. pauloregan
    pauloregan
    Jun 13, 2005
    112
    Crewe, Cheshire
    +6
    I need to connect my playstation2 to my new plasma screen.
    I have a non RGB scart available as well as S Video and Composite Video.
    Which gives the best picture quality?
  2. Pooon
    Pooon
    Dec 26, 2002
    7,127
    Canterbury, Kent
    +731
    s-video
  3. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,583
    2
    Manchester
    +4,365
    You must have other connection options available? Non-RGB scart, s-video and composite are all very poor, and will look terrible on a plasma. You splashed out all that money, why not make it look decent? There must be some other way? :eek: :nono:
  4. pauloregan
    pauloregan
    Jun 13, 2005
    112
    Crewe, Cheshire
    +6
    tv is the 42pd7200 by hitachi.
    This is the spec.
    I am using the 2 RGB scarts for Sky+ and Philips DVD Recorder.
  5. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,583
    2
    Manchester
    +4,365
    Can you not use the pass-through on the DVD recorder? Sky+ > DVDRec > Plasma on one RGB, then the PS2 on the other RGB?
  6. pauloregan
    pauloregan
    Jun 13, 2005
    112
    Crewe, Cheshire
    +6
    I always liked to run a scart to the TV direct from the Sky+ (better picture).
    I have been looking at the component cable input and this seems to be a right can of worms and I am more confused now than I was before!
    Should I buy a Monster Cable Gamelink 400 + Lightwave 100 cable or is there some compatibility issues.
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
  8. pauloregan
    pauloregan
    Jun 13, 2005
    112
    Crewe, Cheshire
    +6
    I thought the Sky+ box had 2 scart outputs and no throught scart (I'm at work, I cannot check).
  9. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    SKy boxes are marked like that but they do indeed work as a passthrough. In fact I havn't found any equpiment with 2 scart sockets that will output RGB on the main one which doesn't pass the signal though. :)
  10. Pooon
    Pooon
    Dec 26, 2002
    7,127
    Canterbury, Kent
    +731
    Thats a good cable choice, if a bit of an expensive one. The offical sony component cable will do a good job for a fraction of the cost and any Toslink optical cable will carry the sound. if you've got a component socket available on your plasma then i'd strongly recommend using it.
