Connect old camcorder to new computer ??
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by loadsofleads, Aug 25, 2004.
  1. loadsofleads
    loadsofleads
    Hi guys, I'm a total newb so please forgive. I have a Samsung VP-A30 camcorder with a av out (small yellow connector like headphones :blush: ) to phono video and phono mono sound out. How the bejesus do I connect this to a computer with Firewire and USB. My Radeon card won't except these. I've had a look on the Maplin site for some kind of Firewire to phono adaptors but no luck.
    Thanks in advance guys. :rolleyes:
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    You need to get a capture card or an analogue/digital converter like the Canopus ADVC-100 you are not going to get a simple connector I'm afraid .
  3. loadsofleads
    loadsofleads
    I see, where could I obtain these items on the internet ?
    Is it cheaper just to get a new camcorder !!
  4. loadsofleads
    loadsofleads
    Found this on ebay, would it do the trick :blush:
  5. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    I don't really know what your intentions are.
    If you want to edit your footage that you capture then you are going to want to have a converter that will capture good quality DV (.avi) files.
    That device looks like it captures MPEG-1 which will not be easy to later edit & is much lower bitrate & resolution than DVD.
    www.dvdrhelp.com is a site that you might like to do some browsing & research on before committing yourself.
  6. Brian110507
    Brian110507
