connect ntl box to bose 321GS
Discussion in 'Cable TV & Virgin Media TV' started by paul75, Jul 30, 2005.
  1. paul75
    paul75
    hi there , i need help connecting my ntl box(samsung) to my bose 321GS system. i want the ntl sound to come from my bose system and not my tv which is a panasonic th42pe30b. is this possible?
    any help would be greatly appreciated. :lease:
  2. mike7
    mike7
    Jan 3, 2005
    4,842
    Norwich
    +585
    As the Samsung box has no Audio outputs you will need to buy a Scart lead with only the audio leads connected. Or you can buy a SCART plug with audio sockets on it so you can plug conventional audion leads to connect to your amp. Not an expensive project. Components are generally available .
  3. paul75
    paul75
    thanks mike, will give it a go.
